12 years ago
connect between sub-blocks at the same and differentE component
Hi ,
i want to connect the control signal - Seed_En (attached file) that his source block is LockStateMachine to :
a. The sub-blocks PN_transmitter at the same component - Rx .
do i need to define the instantiation of the Seed_EN at the Rx block or at LockStateMachine block ?
b. The sub-blocks PN_transmitter at different component - Tx .
do i need to define the instantiation of the Seed_EN at the Tx block or at LockStateMachine block ?
do i need to define output port to the component Rx and instantiate between the Seed_En and the new port ?
do i need to define input port to the component Tx and instantiate between the Seed_En and the new port ?
btw - every component and sub block is different file at the project and there is Top file that define the I/O 's and there is TestBench file
for the project for simulation.
Thanks .
    Inside component "RX" you would write:
    entity RX...
    seed_EN_out : out std_logic;
    architecture...
    signal seed_EN : std_logic;
    begin
    lock_unit : entity work.lockstatemachine
    port map(...
    seed_EN => seed_EN,
    pn_unit : entity work.pngeneratorrx
    port map(...
    seed_EN => seed_EN,
    end architecture...
    did you mean at the instantiate of :
    port map(...
    seed_EN_out => seed_EN,
    port map(...
    end architecture...
    do i need to define seed_En as input port at the entities: lockstatemachine,pngeneratorrx ?
    At the second entity - Tx ,
    do i need to define seed_En_in as input port and instantiate between the Seed_En and the new port ?
    Thanks .
    seed_EN is juist a wire connecting the seed_EN_out ports of the two entites. It would be declared as an internal signal in the design file that instantiates the two entites.
    o.k ,
    i will define seed_EN_out as output port from lockstatemachine , but should i define seed_En_in as input port at the entities:pngeneratortx,pngeneratorrx ?
    and then instantiate : seed_EN_out => seed_EN_in ?
    if not , how will seed_EN be connection between lockstatemachine and the two entities ?
