Confused in logic!
I am New to this coding area!
PLEASE help me clear my basics!
Suppose i have a 4:1 mux and have 4bit input i0,i1,i2,i3, (s0,s1)select lines and output Y.
I use two vcc pins A and B to connect with 4:1.
I want to know that when WE USE RTL Simulation It Give random values to the input and check expected output with the current output , It give random value to A and B or i0,i1,i2,i3.
Can anyone help me design or can anyone design 8:1 mux using 4:1 mux?
If you want to design 8:1 mux using 4:1 mux, perhaps the link below may helps.
Let me know if you need further help with this circuit design.
https://www.tutorialspoint.com/digital_circuits/digital_circuits_multiplexers.htm
- Anonymous5 years agoNot applicable
@RichardTanSY_Altera I want to build 8:! mux using only 4:1 mux and i tried everything but always error occur:(
- RichardT_altera5 years ago
First, you might need to check your design whether it is designed correctly. Like what Strell mentioned, the D2 wire is not connected to s0 in the first 4 mux. Is this expected? Then, check whether the testbench is write correctly.
Are you simulate using Modelsim? Seems to me, "Wrong output to input" error is generated from your testbench and most probably due to design issue, as you got an unexpected output.
You mentioned there is no wave window, have you try to simulate using the flow below, by adding Signals To Wave Window?https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_gs_msa_qii.pdf
@RichardTanSY_Altera Ok Let's start from the beginning! Can you help mw with this project?
1- I code for 4:1 mux please check if you find something wrong! (Code complied successfully)
2-I made a symbol file for 4:1 mux and then give Two inputs A and B .
3-But when is use university program vmf method to check my design error occurs.
All screen shot are provided below.
And last this is i didn't know how to connect A and B with the 4:1 mux i just did random connections as i didn't understand the logic behind connecting 2 bits input with 4 bits input so if you also find something wrong there then please correct me.
