12 years agoconfig support for Quartus?
Does quartus not support verilog config?
I have something like this to indicate to quartus to choose a alt_reset_controller from a different library. I have two of those from two different ip blocks created with megawizard. config cfg1; design uphysvddriii_qr_dimmx64x2clkx2rank_800_cl11_t1.uphysvddriii_qr_dimmx64x2clkx2rank_800_cl11_t1_dmaster; instance dmaster.rst_controller use pcie_de_x8_ast256.altera_reset_controller; endconfig But it seems that Quartus is still confused about which controller to use. Any ideas? Here is the error I get - Error (12179): Instance "IC_1_Bank_B_Ctrl:IC_1_Bank_B_Ctrl_cmp|g_hp_mp_dram:multiport|g_mp2afi:ram|uphysvddriii_qr_dimmx64x2clkx2rank_800_cl11_t1:afi_phy_cmp|uphysvddriii_qr_dimmx64x2clkx2rank_800_cl11_t1_0002:uphysvddriii_qr_dimmx64x2clkx2rank_800_cl11_t1_inst|uphysvddriii_qr_dimmx64x2clkx2rank_800_cl11_t1_dmaster:dmaster|altera_reset_controller:rst_controller" is ambiguous Error (12180): Instance could be entity "altera_reset_controller" in file pciecore/submodules/altera_reset_controller.v compiled in library pcie_de_x8_ast256 Error (12180): Instance could be entity "altera_reset_controller" in file src/xgrx/stratixv/xgrx_rcfg/altera_reset_controller.v compiled in library xgrx_rcfg Thank you. Best regards, Sanjay1 Reply
Have you found a solution? I have the same issue using config/endconfig statement. Thanks, DT
