Conduit signal to control external LEDs; some signal has been "copied"
- 8 years ago
Hello Blee15,
Can you tell us a bit more about what exaclty you are trying to do?
Is your objective to get a led blinking as a first step or are you looking to make a custom Nios component?
If you want to make a blinking LED, you can use a PIO (Parallel I/O) component in nios, export the "external connection" ports and then connect these signals to your DE0-LED's in verilog or VHDL where you instantiate your Nios design.
Johi.
Hello Blee15,
Johi.
