9 years agoConditional assignment statement vs selected assignment statement
Hello, I have some experience with VHDL, but now I am trying to understand the details and not just using the code. What is the difference between the conditional assignment statement an...
9 years agoIn this instance there is no difference, the final logic should be the same.
But with select will always be a normal mux, as all conditions have to be covered. The second example can be used to infer all sorts of logic. In this case it's a priority mux, as r(3) has priority over 2, etc. but you could also infer a latch: code <= ip when en = '1'; or some other logic: code <= a when ip1 = '1' else b when ip2 = '1' else c;
