10 years agoCondition when in vhdl code
Sorry for my bad english, I have a problem in my code: i use the function case x is when y => but instead of a value i would like to have something (>= Y) i don't know if it's possible bu...
10 years agoWhat fpga are you using, your code shouldn't use too many les. Can you pretty the code? Also, 60hz clock seems a little strange, how do you generate this clock? Usual and recommended method us to use the system clock with 60hz enable
