8 years agoCompute units on emulator
Hi, I would like to say if the emulator considers the use of multiple compute units. I do not have a physical board for working, so if I had more than one compute unit, how does the emulator work?...
8 years agonum_compute_unit(N) is a basic compiler feature for NDRange kernels and it is fully supported in the emulator. The users does not need to change anything in the host or kernel code, other than adding the associated attribute. The compiler will automatically handle pipeline replication and distribution of work-groups over the multiple compute units. Functionally, the emulator behaves in the exact same way as the actual hardware does. However, you should not expect to see a speed-up in the emulator by using this attribute, since the emulator is not timing-accurate.
