9 years agoComplier Error, Quartus Prime Fitter was unsuccessful
I tried to compile a compution.cl file with aoc command to generate computation.aocx.(The command line is aoc -v computation.cl -o computation.aocx) But It failed to generate .aocx file and only .aoco file was generated. With the -v , it showed the stage of compiling on the screen and the information is :
------screen-------
aoc: environment checks are completed successfully.
you are now compiling the full flow!!
aoc: selected default target board a10gx
aoc: running opencl parser....
aoc: opencl parser completed successfully.
aoc: compiling....
aoc: linking with ip library ...
warning: kernel 'fullylayer' has unused argument 'inputdatasize'
aoc: first stage compilation completed successfully.
error: compiler error, not able to generate hardware
Then I checked computation.log in the computation floder. It showed no error occured :
-------computation.log---------
info: quartus prime shell was successful. 0 errors, 0 warnings
info: peak virtual memory: 581 megabytes
info: processing ended: fri jun 16 09:08:55 2017
info: elapsed time: 00:00:34
info: total cpu time (on all processors): 00:00:00
Then I checked top.fit.rpt for more information and the usage of resource in this file showed the resource was enough: +--------------------------------------------------------------------------+
; fitter summary ;
; fitter status ; failed - fri jun 16 13:32:10 2017 ;
; quartus prime version ; 16.1.1 build 200 11/30/2016 sj pro edition ;
; revision name ; top ;
; top-level entity name ; top ;
; family ; arria 10 ;
; device ; 10ax066n3f40e2sg ;
; timing models ; final ;
; logic utilization (in alms) ; 30,540 / 251,680 ( 12 % ) ;
; total registers ; 302754 ;
; total pins ; 290 / 812 ( 36 % ) ;
; total virtual pins ; 0 ;
; total block memory bits ; 22,860,776 / 43,642,880 ( 52 % ) ;
; total ram blocks ; 218 / 2,131 ( 10 % ) ;
; total dsp blocks ; 234 / 1,687 ( 14 % ) ;
; total hssi rx channels ; 8 / 48 ( 17 % ) ;
; total hssi tx channels ; 8 / 48 ( 17 % ) ;
; total plls ; 57 / 96 ( 59 % ) ;
but at the end of top.fit.rpt, it reported some errors :
----------top.fit.rpt----------error (18999): placement cannot find a legal solution.
info (170191): fitter placement operations beginning
info (170192): fitter placement operations ending: elapsed time is 00:01:11
info (11888): total time spent on timing analysis during placement is 572.60 seconds.
error: an error occurred during placement
info (144001): generated suppressed messages file c:/users/xinzhou/desktop/dnn_1.1.1.1/bin_profile/fully_layer/top.fit.smsg
error: quartus prime fitter was unsuccessful. 5 errors, 1014 warnings
error: peak virtual memory: 24521 megabytes
error: processing ended: fri jun 16 13:32:25 2017
error: elapsed time: 03:02:03
error: total cpu time (on all processors): 08:17:02
; fitter suppressed messages ;
the suppressed messages can be found in c:/users/... --------------
What's more, my OS is Windows 10 Professional , Quartus version is 16.1.1, AOC version is 16.1.0, and It generated .aocx file successfully Before with other OpenCL kernel file. Why it failed to generate .aocx file? And what should I do to shoot this trouble? I am waiting for your reply. Thank you.
The FPGA board's memory is problematic.
