9 years agoComplier Error, Quartus Prime Fitter was unsuccessful
Hi, I tried to compile a compution.cl file with aoc command to generate computation.aocx. (The command line is aoc -v computation.cl -o computation.aocx) But It failed to generate .aocx file...
9 years agoI've solved this problem with the Intel FPGA SDK for OpenCL Custom Platform Toolkit User Guide, section 1.4.4. I checked register key named HKEY_LOCAL_MACHINE\SOFTWARE\Altera\OpenCL\Board and deleted the redundant item that added by another version of Quartus. The MMD ERROR disappeared.
--- Quote Start --- "windriver" sounds like the OS is windows. I have never used Windows for this particular work. If the OS is NOT Windows, then there must be something seriously wrong with the BSP they have provided you with. --- Quote End ---
