9 years agoComplier Error, Quartus Prime Fitter was unsuccessful
Hi, I tried to compile a compution.cl file with aoc command to generate computation.aocx. (The command line is aoc -v computation.cl -o computation.aocx) But It failed to generate .aocx file...
9 years agoOnly the hardware folder? That sound strange. I think they should also correct timing settings in the PCI-E driver and provide their own driver.
What you describe can have two explanations: - There is something wrong with the BSP or the PCI-E driver. - The FPGA board's memory is problematic. Based on what you describe, I see the former as the more likely reason.
