9 years agoComplier Error, Quartus Prime Fitter was unsuccessful
Hi, I tried to compile a compution.cl file with aoc command to generate computation.aocx. (The command line is aoc -v computation.cl -o computation.aocx) But It failed to generate .aocx file...
9 years ago --- Quote Start --- --------------------Update-------------------- My DSP package do not support 16.1.2 and higher version, this is the reason that the strange errors occured. --- Quote End --- DSP or BSP? It seems you are using Altera's Arria 10 devkit; the BSP for that board is updated with every version of Quartus and is included in the package itself. There should be no need to use an older version of Quartus/AOC.
