18 years agoCorrect, the 1st line in the message window, Processing tab, is the error.
In the System tab when trying your suggestion I received; Info: Started Analysis & Synthesis at Mon Nov 05 13:25:18 2007 Eastern Standard Time Info: Ended Analysis & Synthesis at Mon Nov 05 13:25:26 2007 Eastern Standard Time Strange indeed. I will try an SR and also see if I can find a work around. Thank you for your time. Regards, rfournier
