18 years agoStrange. When you compile a design, it is really just running some command line arguments. These get echoed into the messages at the bottom, like so:
quartus_map -options .... quartus_merge -options .... quartus_fit -options .... Etc. Can you look at the command being run and what options are set? Also, go to your old, working project and look at the .flow.rpt, which should have all these commands grouped together. Then we compare the two and see what's different.
