8 years agoComplex loop exit condition
Hello, I have a very simple code with a few lines, but the outer loop is not pipelined due to "Loop exit condition unresolvable at iteration initiation". Inner loop is pipelined well with II=1. Ca...
8 years ago --- Quote Start --- 2- I tested the ND-range. That really worked well! I don't know exactly what is the difference between implementation of pipelinging inside a task, or pipelining among work-items inside a ND-range, however, this is a good example for me that they are not similar. --- Quote End --- The difference is that the run-time scheduler in the NDRange version will avoid all the redundant computation. NDRange is preferred for unpipelineable loops because of this (while single work-item is preferred for pretty much every other case).
