13 years ago --- Quote Start --- Simply use quartus_map "quartus_map -h" for argument list, but at the high level, all you need is "quartus_map <revision_name>" where revision_name is the base name of your qsf (no extension) --- Quote End --- Thanks. I found it. "quartos_sh --flow analysis_and_elaboration <projectname>" does the compilation.
