11 years agoCompiler Problem
Dear all, Device : max II. The module function is to latch to 1 at the SignalIn risign edge. The code1 works well. As you know, there is an internal reset signal in MAX II device. so we ...
11 years ago --- Quote Start --- Dear all, Device : max II. The module function is to latch to 1 at the SignalIn risign edge. The code1 works well. As you know, there is an internal reset signal in MAX II device. so we don't need to reset to 0; So I write code 2, it works well in modelsim, but it will not work in Quartus. In quartus , the bit is always 1. The reason is that quartus will optimize and will not see the default reset action. So, how can i make the code 2 work correctly? perhaps iis there an option used to cahnge compiler action? thanks;) /////////////////////////////////////////// // code 1 /////////////////////////////////////////// input wire nrst;
output reg bit;
always @ (negedge nrst, posedge signalin)
if (!nrst)
bit <= 0;
else
bit <= 1; /////////////////////////////////////////// // code 2 /////////////////////////////////////////// output reg bit;
always @ (posedge signalin)
bit <= 1; --- Quote End --- code 1 has reset, code 2 has no reset so what is the problem. The global powerup reset has nothing to do with code.
