9 years ago
Compile kernel as task not as NDRange
My design has multiple kernels communicating through channels forming a chain like this:
Kga -> Kconf -> Kene -> Kst
It is running correctly in emulation, but some information in the optimization report seems strange to me:
Specifically, one kernel (Kga) is compiled as NDRange, although no work-item function is used in any kernel.
Is there any function/statement that is causing this kernel to be compiled as NDRange?
    Thanks for the info.
    I added that attribute, but unfortunately that kernel is still being compiled as ND-Range.
    The log shows warnings:
    "Compiler Warning: Channel ordering barrier insertion in X of Kernel Kga, but kernels may hang as a result"
    I don´t know how to interpret this warning. Have you experienced something like this before?
    If you are able to post your code it will help immensely :)
    I recompiled it and now it gets compiled as task.
    thank you.
    An alternative to using __attribute__((max_global_work_dim(0))) is also __attribute__((task)) which should also do the same thing
