9 years agoCompilation incompatibilities Modelsim-Quartus (component conditional generation)
Hello, We're having some issues while trying to compile a project generated with Quartus 13.1 using Modelsim-Altera Starter Edition 10.1. The problem is due to a conditional instantiation ...
9 years agoActually - this is important:
Error (287078): Assertion error: The current megafunction is configured for use with the clear box feature and cannot be used when the clear box feature is disabled Did you generate a netlist for this ram? If thats the case, you need to use the ram as you generated it. If it was generated with 2 clocks, then you need to provide 2 clocks. All my suggestions assume you have NOT generated the ram using the megawizard, and are trying to control the ram yourself.
