davidyu1
3 years agoCompilation fail duo to hps_csdram_p0
We used platform designer and use hps IP to build our design.
But Compilation failed and had the following message:
Error: The auto-constraining script was not able to detect any instance for cor...
anonimcs
Contributor
2 years agoHi,
I'm not using a golden ref design but I have similar errors at the fitter stage (I'm using Quartus 17.1 Standard on Ubuntu 20.04). I tried removing the db/ and incremental_db/ folders and the run a full compilation as well, but it didn't help. If anyone knows the fix, that'd be great to find out.
Cheers
