davidyu1
3 years agoCompilation fail duo to hps_csdram_p0
We used platform designer and use hps IP to build our design.
But Compilation failed and had the following message:
Error: The auto-constraining script was not able to detect any instance for cor...
aikeu
3 years agoHi davidyu1,
I understand that you have modified the golden design example of DE10 nano. I not very sure the problem from your modification other than adding additional soft IP which connect to the bridge.
Anway can try run with other example like from previous link or any example which uses a PIO controller IP:
https://www.rocketboards.org/foswiki/Documentation/SoCEDS
From there only add on your modification.
Aik Eu
