davidyu1
3 years agoCompilation fail duo to hps_csdram_p0
We used platform designer and use hps IP to build our design.
But Compilation failed and had the following message:
Error: The auto-constraining script was not able to detect any instance for cor...
aikeu
3 years agoHi davidyu1,
May I know which document which you refer to build your project?
The original ghrd used was working fine without compilation issue or after you modify it only got issue?
Aik Eu
- davidyu13 years ago
Hi Aik Eu,I created new project with your de10-nano template file(DE10_Nano_golden_top.qar) and use platform designer to add hps-to-fpga interface in my design.You can see my project files I attached the post previously.I found that the compilation issue is from adding hps-to-fpga interface.If I remove hps-to-fpga interface from qsys, the compilation is without error.
