10 years ago
Comparison between old value and new value
Hi All,
Its a very simple question but I am unable to do that. Below is my code. I want to store signal data_o_new to signal data_o_old and then compare these signals with each other and do increment or decrement until these two signals become same. data_o_new is coming from an ip. Please help me... thanks
Architechture starts here:
Begin
data_o_old <= data_o_new;
data_o <= data_o_old;
fading: PROCESS(clk)
Begin
if rising_edge(clk) then
if data_o_new > data_o_old then
data_o_old <= data_o_old + 1;
elsif data_o_new < data_o_old then
data_o_old <= data_o_old - 1;
else
end if;
end if;
end process;
end Architecture;
    then why not do something like this?
    signal value_ref : unsigned(Nbits-1 downto 0);
    signal output_ref : unsigned(Nbits-1 downto 0);
    process(clk)
    begin
        value_ref <= new_value;
        if value_ref > output_ref then
          output_ref <= output_ref +1;
        elsif value_ref < output_ref then
          output_ref <= output_ref -1;
        end if;
      end if;
    end process;
    op <= output_ref;
    Here, the output never changes dramatically, but is gradually pulled towards your new value.
    --- Quote Start ---
    I dont want abrupt change of new value. that's why I store the new value to a signal then do increment or decrement to that signal while my signal is going to output having a smooth transition.
    --- Quote End ---
    A more practical approach is running average filter, it does not need any mults, you just add say 8 samples together then discard 3 Lsb off result.
    If you are aiming at incrementing/decrementing by 1 you may either not have enough time to catch up or you have more gaps
    thanks tricky... I dont understand what is initial value of output_ref?? So how it can be compared
    --- Quote Start ---
    --- Quote End ---
    Sorry, I should have initialised it - you could do it like this:
    signal output_ref : unsigned(Nbits-1 downto 0) := (others => '0'); --or whatever value you want
    or with a reset.
