8 years agoComparing waveform values
Hello !
I'm using MAX+ BASELINE I need your help in one project: "Design a system that avergaes the amplitude of the signal given from the generator. a) We set the averaging 2,4,8 or 16 measurements with the button. Average result should be dispalyed on the oscilloscope. b) Averaging the amplitude value for the run period Compare the average value with the programmed values (max and min values)" How can I compare all waveform values (f.e. sine wave) and save the max and min values (and amplitude)? If you want i can send you a part of the project, what i've done.No RepliesBe the first to reply
