11 years agoHi Pete,
--- Quote Start --- Thanks for the expanded answer. However I get an error saying that save_script.tcl does not exist when I run the command. --- Quote End --- That is the script you download from the Wiki page I linked to. --- Quote Start --- I created my own script that uses the export_hw_tcl command to write the hw.tcl file though. --- Quote End --- So that I can help you, I'd like to compare the method you are using (Qsys Export to _hw.tcl) versus the Wiki script ... which version of Quartus are you using? In the meantime, synthesize the DE0-nano SDRAM design and look at the qsys_system.tcl script. Once you have built that design, use the Qsys export as hw.tcl option and see if its the same (or at least similar). Cheers, Dave
