Altera_ForumHonored Contributor15 years agoCombine/Map one bus onto another Hello, Would someone be able to explain how to combine bits from two different buses? Say I had two buses Source[23..0] and Sink[21..0] - I want to map a number of bits from Source onto ...Show More
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
