9 years agoCombinational Loop In VHDL synthesis
Dear all I've been working on a project in which I build an interconnection network with similar modules. Each module has 4 inout dataports. Also they have two control ports, one for R/W (Read or ...
9 years agoThe combinational loops are pretty clear. In your first assignment, PortL0 drives PortR0 and then in your third PortR0 drives PortL0. You of course intend the when clauses to make them mutually exclusive, but I doubt if the tools are that smart. You should use the proper VHDL constructs for mutually exclusive cases:
if(SW='0' and RW='0') then
PortR0 <= ...
PortR1 <= ...
PortL0 <= ...
PortL1 <= ...
elsif(SW='0' and RW='1') then
elsif(SW='1' and RW='0') then
else
end if;
Or a case statement:
test_proc : process(RW, SW, PortR0, PortL0)
variable sel : std_logic_vector(1 downto 0);
begin
sel := SW & RW;
case sel is
when "00" =>
PortR0 <= PortL0;
PortL0 <= 'Z';
when "01" =>
PortL0 <= PortR0;
PortR0 <= 'Z';
when others =>
PortR0 <= 'Z';
PortL0 <= 'Z';
end case;
end process;
You could still run into trouble though with multiple drivers at a higher level. It's not entirely clear what you are trying to do, but inout's are best avoided.
