11 years ago
Code seems fine, can't find out where these errors are at. :(
Hi, I'm trying to make a vending machine project in VHDL for a class, and I keep getting errors that I can't resolve. I would really appreciate some advice!:
Error (10500): VHDL syntax error at vending_machine.vhd(21) near text "THEN"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at vending_machine.vhd(36) near text "THEN"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at vending_machine.vhd(38) near text "THEN"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at vending_machine.vhd(51) near text "THEN"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at vending_machine.vhd(53) near text "THEN"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at vending_machine.vhd(66) near text "THEN"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at vending_machine.vhd(68) near text "THEN"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at vending_machine.vhd(81) near text "THEN"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at vending_machine.vhd(83) near text "THEN"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at vending_machine.vhd(96) near text "THEN"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error at vending_machine.vhd(98) near text "THEN"; expecting "(", or "'", or "."
Here is my code:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY vending_machine IS
PORT (clk, rst: IN STD_LOGIC;
nickel_in, dime_in, quarter_in: IN BOOLEAN;
candy_out, nickel_out, dime_out: OUT STD_LOGIC);
END vending_machine;
ARCHITECTURE fsm OF vending_machine IS
TYPE state IS (st0, st5, st10, st15, st20, st25, st30, st35, st40, st45);
SIGNAL pr_state, nx_state: state;
ATTRIBUTE enum_encoding: STRING;
ATTRIBUTE enum_encoding OF state: TYPE IS "sequential";
BEGIN
PROCESS (rst, clk)
BEGIN
IF (rst='1') THEN
pr_state <= st0;
ELSEIF (positive_edge(clk)) THEN
pr_state <= nx_state;
END if;
END PROCESS;
PROCESS (pr_state, nickel_in, dime_in, quarter_in)
BEGIN
CASE pr_state IS
WHEN st0 =>
candy_out <= '0';
nickel_out <= '0';
dime_out <= '0';
IF (nickel_in) THEN
nx_state <= st5;
ELSEIF (dime_in) THEN
nx_state <= st10;
ELSEIF (quarter_in) THEN
nx_state <= st25;
ELSE
nx_state <= st0;
END if;
WHEN st5 =>
candy_out <= '0';
nickel_out <= '0';
dime_out <= '0';
IF (nickel_in) THEN
nx_state <= st10;
nx_state <= st15;
nx_state <= st30;
ELSE
nx_state <= st10;
END if;
WHEN st10 =>
candy_out <= '0';
nickel_out <= '0';
dime_out <= '0';
IF (nickel_in) THEN
nx_state <= st15;
nx_state <= st20;
nx_state <= st35;
ELSE
nx_state <= st10;
END if;
WHEN st15 =>
candy_out <= '0';
nickel_out <= '0';
dime_out <= '0';
IF (nickel_in) THEN
nx_state <= st20;
nx_state <= st25;
nx_state <= st40;
ELSE
nx_state <= st15;
END if;
WHEN st20 =>
candy_out <= '0';
nickel_out <= '0';
dime_out <= '0';
IF (nickel_in) THEN
nx_state <= st25;
nx_state <= st30;
nx_state <= st45;
ELSE
nx_state <= st20;
END if;
WHEN st25 =>
candy_out <= '1';
nickel_out <= '0';
dime_out <= '0';
nx_state <= st0;
WHEN st30 =>
candy_out <= '1';
nickel_out <= '1';
dime_out <= '0';
nx_state <= st0;
WHEN st35 =>
candy_out <= '1';
nickel_out <= '0';
dime_out <= '1';
nx_state <= st0;
WHEN st40 =>
candy_out <= '0';
nickel_out <= '1';
dime_out <= '0';
nx_state <= st35;
WHEN st45 =>
candy_out <= '0';
nickel_out <= '0';
dime_out <= '1';
nx_state <= st35;
END CASE;
END PROCESS;
END fsm;
    --- Quote Start ---
    Never heard of positive_edge. May be you mean rising_edge
    --- Quote End ---
    I tried changing it to rising_edge, and originally had it as (clk'EVENT AND clk='1') but neither work...
    --- Quote Start ---
    It is "elsif" not "elseif"
    --- Quote End ---
    Thank you! Can't believe I missed that syntax. Appreciated.
