14 years agoHi everyone,
I performed more advanced tests and I figured out that it is not only PMA direct receiver reconfiguration which fails, but any Receiver reconfiguration (PMA direct or Basic). The error is a "mif type" error, and the bit on the mif file, which leads the simulation to an error is reconfig_data(11) on the first line of the mif file. This bit is high for Tx and low for Rx. However, I have no idea what this difference means, and I couldn't fine any documentation about it. I simply want to dynamically switch from a reference clock to another at the multiplexer input of the receiver. I really can't see why receiver reconfiguration wouldn't be possible, because the option is available in the mega wizard... Thank you very much ! Regards
