16 years ago --- Quote Start --- why two clocks --- Quote End --- You didn't read the paper thoroughly. clk1 is simply representing the other clock domain. It's not belonging to the synchronizer. As a side remark. The common problem with processing of asynchronous external signals is not metastability. It's to completely omit synchronizing and feed the signal directly to multiple registers. In a simple example:
IF external_signal = '1' THEN
next_state = triggered;
END IF; next_state is fed to a number of registers representing the state variable. Each register is sampling independently a combinational input depending among others on external_signal. If the edge of external_signal coincides with the clock edge, the state variable can be set to a wrong or even illegal state. This problem hasn't to do with metastability, it's a simple case of missing synchronization. Providing a single synchronizing register removes nearly all of the above problems. The metastability discussion is about those cases, where a single register isn't enough.
