10 years agoclock problem
greetings
hi guys am having an assignment which it basically a car park machine it has 4 inputs which is fifty , twenty, ten, ticket and i need to detect the input and deduct it from an amount of 1.50 so basically i made the design for the stages and the decoder to view it in four 7-seg bcd which starts with insert ticket then remove ticket then the 1.50 to check the input of the user and heres my problem comes when i apply the code in de1 altera board the 7-seg doesn't show the first two stages it goes straight away to the 1.50 stage , that happens due to the clock is so fast even the inputs, lets say i pressed the input 50 the whole process can be done with single press and am using 50MHZ clock so i tried to use a clock divider code to reduce it to 1HZ but it seems that the problem is still there so is there any way that i can slow the clock so the first two stages can be shown to the user --------------------------------------------------------------------------- library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity clk200 is Port ( clk_in : in STD_LOGIC; rst1 : in STD_LOGIC; clk_out: out STD_LOGIC ); end clk200; architecture Behavioral of clk200 is signal temporal: STD_LOGIC; signal counter : integer range 0 to 49999999 := 0; begin frequency_divider: process (rst1, clk_in) begin if (rst1 = '1') then temporal <= '0'; counter <= 0; elsif rising_edge(clk_in) then if (counter = 49999999) then temporal <= NOT(temporal); counter <= 0; else counter <= counter + 1; end if; end if; end process; clk_out <= temporal; end Behavioral; -------------------------------------------------------------------- what i need is method that slow down the clock to the lowest thank1 Reply
