18 years ago --- Quote Start --- Looking at the first picture i posted: http://img120.imagevenue.com/img.php..._122_747lo.jpg The clock network delay + data delay values should ensure that the hold and setup times are met. --- Quote End --- That link didn't work for me, but it sounds like you're looking at the same timing report to look at both tco (setup) and min tco (hold). Did you do report_timing for both setup and hold for the device output pins?
