Clock missing from Timing Analyzer - Report Setup Summary
What are all those false paths you've created? Are you preventing analysis on the paths that are clocked by HDMI_TX_CLK?
Run Report Timing and specify you're looking for paths clocked by this clock.
Those false paths were the ones setup in Timing Analyzer by default and placed in the sdc file. All I did was add HDMI_TX_CLK into the "Create Clock" group in the sdc file.
I have no idea why it would do that and I don't recognise the names.
- sstrell2 years ago
So you should run detailed timing reports with Report Timing, setting the launch or latch clock as HDMI_TX_CLK to find paths clocked by this clock domain.
- Mikexx2 years ago
If I go to Custom Reports -> Report Timing I an enter HDMI_TX_CLK into the from and to clock. These exist in the pull-down option.
I placed * in the targets entry, leave it blank, or add all registers in the design. I get "Nothing to report" for all options.
Not sure if it makes a difference bu I'm using Quartus Prime Version 20.1.0 Build 711 06/05/2020 SJ Lite Edition
