15 years agoHi,
if you register both the inputs and outputs, you have a 2 cycle latency. This will work for sure at 20MHz. Actually, I did a quick implementation of that equation on a Cyclone III, with all the factors being registers, and the fMax is 93MHz. To achieve a single cycle latency, one has to drop either the input or output registers. And then one has to do a more careful analysis, including ADC tco or DAC tsu/th and board delays. But my guess is that yeah, it's probably doable at 20 MHz. Quite honestly, I never use BDF, so I'm totally unfamiliar with it. But yes, it should be related to pipelining options or registered input/output options.
