15 years agoClock Enable on global routing
I need to use a gated clock in my S3 design, and have the choice between using the recommended clock gating circuit or a clock enable. If I use clock enable, will that aggravate the routing congestion because clock enables are routed as regular signals or are they routed as clocks on global clock networks.
