11 years agoThe clock input for signal tap is the 250Mhz clock, but I also added the 125Mhz clock enable as a reference. All the _tp signals are the actual signals run through a register to ease timing. Helps with loading of signals for signaltap.
I would post more code, but the failures varies throughout the project. Should I be concerned about the phase relatationship of the 250 and 125 clock enable, or should the tool take care of that? Is it possible a SDC constraint is causing this?
