amildm
Contributor
4 years ago[Clock Domain] Tracing a signal
Hi All,
Is there an easy way to trace/report, what clock drives a specific cell?
Please consider two cases:
1) the reported/traced cell is FlipFlop - this should be an easier way since the cl...
sstrell
4 years agoYou can also use the Timing Analyzer to cross-probe any path to the Chip Planner to see the path as it's routed in the device.
amildm
Contributor
3 years agoCould you please explain more? Is there some video or tutorial, which explains how to check what clock domain the given signal belongs to?
Is there a TCL command or procedure, which could help in this case?
Thanks!
