10 years agoclock division
Greetings everyone, I'm trying to divide the clock frequency by 2, 4, 8 for a (4x1 Multiplexer) in which the first input is the clock but the other three are the clock divided by the above numbers. ...
10 years agoYour code currently does nothing for several reasons:
1. You are only trying to initialise the variables - they are not changing dynamically 2. You cannot divide a single bit by anything. I suggest using a counter somewhere. I also suggest you do not use the clock any any logic equation, or generate a clock from logic. Doing this is very bad practice - you need to generate clock enables instead.
