I need a clock divider to run a T80 core at 3,58Mhz
For the first code I tried to slow clock output to see if led blink well but I saw nothing.
This one would be handy because clock could be set precisely.
The second is to difficult to understand for me.
The best result I had for now is with a simple counter like that but I'm not sure of clk_out.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity CLOCK3_57 is
port (clk_in : in std_logic;
clk_out : out std_logic;
reset_n : in std_logic
end entity CLOCK3_57;
architecture Behavioral of CLOCK3_57 is
signal temporal: STD_LOGIC;
signal counter : integer range 0 to 6 := 0;
begin
frequency_divider: process (reset_n, clk_in) begin
if (reset_n = '0') then
temporal <= '0';
counter <= 0;
elsif rising_edge(clk_in) then
if (counter = 6) then
temporal <= NOT(temporal);
counter <= 0;
else
counter <= counter + 1;
end if;
end if;
end process;
clk_out <= temporal;
end Behavioral;
