Ok I try this :
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
entity CPU_CLOCK is
port (CLK : in std_logic;
n_clr : in std_logic;
clk_en: out std_logic );
end entity CPU_CLOCK;
architecture arch of CPU_CLOCK is
signal cont_reg, cont_prox : unsigned(3 downto 0);
begin
process(n_clr, clk)
begin
if ( n_clr = '0' ) then
cont_reg <= ( others => '0' );
elsif( clk'event and clk = '1' ) then
cont_reg <= cont_prox;
end if;
end process;
cont_prox <= cont_reg + 1 when ( cont_reg < 11 ) else
( others => '0' );
clk_en <= '1' when ( cont_reg = 0 ) else
'0';
end arch;
