It's not a good practice to use clock divider in fpgas. Instead you should use clock enable. You may have problems if you use different math libraries like numeric_std and math_real. With numeric_std it's enough.
This is the code for a clock enable:
architecture....
signal cont_reg, cont_prox : unsigned(3 downto 0);
begin
process(n_clr, clk)
begin
if ( n_clr = '0' ) then
cont_reg <= ( others => '0' );
elsif( clk'event and clk = '1' ) then
cont_reg <= cont_prox;
end if;
end process;
cont_prox <= cont_reg + 1 when ( cont_reg < 11 ) else
( others => '0' );
clk_en <= '1' when ( cont_reg = 0 ) else
'0';
It counts from 0 to 12. You can get the 3,75MHz frequency with this approach. A clock divider could be implemented if you change last line:
clk_en <= '1' when ( cont_reg < 6 ) else
'0';
