13 years ago
clock distribution in quartus
Hello all,
are there any tutorials/help documents concerning how the clock signals
should distributed in quartus?
the problem i have is that when my quartus/nios project reaches a certain
size the pll can't generate a 80MHz clock anymore.
the project has one big nios and several mmp blocks, all running with the same 80MHhz clock.
should i us one pll which generates one clock signal for all (nios+mmps) or one pll generating four 80MHz signals. when should the global primitive be used?
thanks in advance!
    Quartus automatically uses the global clock network, and you can use a single clock in all your design, it shouldn't depend on the project size.
    What do you mean by "can't generate"? What error message do you get?
    thanx for your reply, my PLL does not lock anymore, but you are right that the project size is not the problem. Some additional MMPs caused the problem (setup and hold violations).
