12 years ago --- Quote Start --- Hello friends, recently, i have been asking questions on this forum. Pls dont get upset at my questions if they are too elementary. This is because i'm new to this area and i've got a deadline for my final project. Again i like to ask, programming VHDL in quartus II... Where exactly does one set the actual clock and gain value for a comparator? Is it at the wave vector or in the VHDL code itself. I understand this could be done in the wave vector, for simulation (synthesis). But for the actual implementation in a Stratix iii device, are the wave vector values still valid??? Cos it seems to me that only the VHDL code is loaded into the device and not with the wave vector value. pls clarify me on this. --- Quote End --- you better tell us what you want to design; a comparator of two inputs? one input set to a constant? forget about clock now as that is the easy bit. Also forget about simulation waveforms as it has nothing to do with implementation. You implement first then simulate and not the other way round.
