Chip planner - modern art?
- 3 years ago
There aren't different tools, they are the exact same tool.
The second screenshot is the Vivado's Chip planner equivalent. It exactly shows the actual resources used by the device and we can even see the routing resources. Surprising how obsolete Intel is, isn't it?
We can even color the resources we want, with different colors: (source: https://www.xilinx.com/content/dam/xilinx/support/documents/sw_manuals/xilinx2021_2/ug906-vivado-design-analysis.pdf)
I'll stop the comparison here, it's too shameful for Intel.
From your answers, I assume the view is correct and is expected.
Quartus is seriously miserable compared with the concurrent it tries to compete with.
These are two completely different tools. The Chip Planner is used to view device resources and how they are used by your design. You usually use the Chip Planner to analyze the results of place and route to help solve timing issues, but you can also use it to allocate resource usage for a part of the design. If you zoom out the image you posted, you'll see where these resources are physically located on the device.
Your second screenshot is of a schematic editor or RTL viewer, a schematic representation of a design, not the actual resources used by the device. Quartus has a schematic editor and an RTL viewer that are used for a view like this.
- alexislms3 years ago
Contributor
- sstrell3 years ago
Well you’ve clearly made your choice. So what’s the point of your post?- alexislms3 years ago
Contributor
To make sure what I'm seeing is actually what is expected. I couldn't believe it and wanted a confirmation.
And also because I have no other choice than using Quartus...
