13 years ago
Check two different clocks
I have two clock signals: clock_50 (50MHz) and clock (16kHz). Now I want FPGA to do three commands within each clock (16kHz), the commands are done in one clock_50 (50MHz).
I tried but it doesn't work. The idea is the same following lines, but I dont know how to code it
always @(posedge clock) begin
     always @(posedge clock_50) begin
         //do a command
         //do a command
         //do a command
     end
end
Could you please help me?
    You should consider only the 50MHz faster signal as the 'real' clock.
    Use a single always @(posedge clock_50) . Inside this process latch the 16kHz signal into a register and whenever you spot a change to state high trigger your 3 command sequence.
    Thank you for your reply.
    But I want to generate 3 sub-clocks . I tried
    always @(posedge clk or negedge rst_n) begin
    	if (!rst_n) begin // reset the registers
    		count = 0;
    	end else begin
    		count_cal = 5'b00000; // reset
    	end
    end
    always @(posedge clk_50 or negedge rst_n) begin
    		flag_cal = 0;
    		count_cal = 0;
    	end else begin
    		if (clk) begin
    			count_cal = count_cal + 5'b00001;
    			if ((count_cal > 1) && (count_cal < 7)) //
    				flag_cal <= flag_cal + 1'b1;
    			else
    				flag_cal <= 1'b0;
    		end
    	end
    end
    always @(posedge flag_cal or negedge rst_n) begin
    // this is to do 3 commands
    However it cannot elaborate successfully.
    @Cris72
    As you said I just do some commands within a hafl of clock cycle, not within the whole clock cycle
