11 years agoChannel problem
Hi There are two kernel functions to communicate with each other by using channels. __kernel void producer(...) { // N threads int sum = get_global_id(0); write_cha...
11 years ago__attribute__((reqd_work_group_size(NUM_THREAD, 1, 1)))
__kernel void vectorAdd(__global const float * restrict x, __global const float * restrict y, int numElements) //numElements = globalSize = 1024000 { // get index of the work item int index = get_global_id(0); int lid = get_local_id(0); if (index >= numElements) { return; } float sum ; sum = x[index] + y[index]; write_channel_altera(read , sum); } __kernel void sum(__global float * restrict c) //Task { float sum_add , temp = 0.0; c[0] = 0.0 ; int cnt = 0; for(cnt = 0 ; cnt < globalSize ; cnt++){ sum_add = read_channel_altera(read ); temp += sum_add; } *c = temp; } It seems that the code above is not efficient . In my case (DE5-NET) , it needs ~40ms to finish the kernel , and at step ( c[0] = temp ) it needs 8 clock stall (use -g to report) . """"""""""""""""""""" Successive iterations launched every 8 cycles due to: Data dependency on variable temp Largest Critical Path Contributor: 96%: Fadd Operation """""""""""""""""'""" But the reduction example (altera provides) is doing the same thing , and says that this method is more efficient. I don't understand what's the problem about this code . And I want to ask how many private memory per workitem could use ? Thanks.
