11 years ago --- Quote Start --- You may be able to create your own FIFO in global memory with a global array and two scalars indices--front and back--defined at program scope. Then you could use the atomic integer functions to manipulate the front and back indices as needed. --- Quote End --- How would these program-scope indices be implemented? Would atomic functions be costly on them? I'm not interested in an off-chip FIFO, but just wondering...
