11 years agoThe questin is, where is the channel physically located? I am assuming, AOCL uses local (on-chip) memory resources to implement channel. If it is right, the channel would be limited by size. Is it possible to implement the channel using off-chip memory resources when the latency is not an issue?
If AOCL is not using local memory resources, how channel is implemented?
