11 years ago
Channel from many work items to single task
I am trying to compile something that is computing something with many work items. They are spit out to a channel into a single work item. There is no way to know how many at compile time but i get this error:
Channel Pairing Type Does not match
Channel c0 needs one chan_read_altera and one chan_write_altera.
Multiple chan_read_altera/chan_write_altera with the same channel ID may cause this problem.
system_integrator: custom_ic_impl.cpp:4422: void custom_ic::System::build_channel_system(): Assertion `0' failed.
There is only one of each channel read/write call in the code and i the different kernels (one in the multiple work item, the other in a single task)
Any ideas?
Stephen
Edit: I think i realized why. Is it that the number of of calls has to be defined to be the same? (ie static?) If so that sucks ... i obviously want to read and write N times in each kernel but can i vary N?
    Your channel c0 has multiple chan_write_altera but one chan_read_altera to channel c0. It is not allowed.
    I wished to have N work-items in the write kernel, and call the single task kernel reading N times.
    I have found that with the static (defined) N, this seems to be faster.
    I now want to be able to vary the work group size of the writer, and pass N as a parameter to the single task kernel.
    The error above is what i got. Any way around it?
    Stephen
    --- Quote Start ---
    Stephen
    --- Quote End ---
    I actually am interested in doing so, too. You mean that with a static global size, it does work?
    How do you define a static global size at compile time? I thought we only can specify it in the call to enqueueNDRangeKernel().
    Hmm i think it was just with the -O3 optimization flag. Prob just a bug then. Heres some examples that work
    __kernel void producer (__global int * in_buf, int N)
    for (int index=0; index < N; index++)
    write_channel_altera( c0, in_buf );
    __kernel void consumer (__global int * ret_buf, int N)
    for(int index=0; index < N; index++)
    ret_buf = read_channel_altera( c0 );
    This is what i meant by static ...
    #pragma OPENCL EXTENSION cl_altera_channels : enable
    channel int c0;
    # define N 256
    __attribute__((reqd_work_group_size(N,1,1)))
    __kernel void producer (__global int * in_buf)
    int gid = get_global_id(0);
    __kernel void consumer (__global int * ret_buf)
    This is what i was trying to do. Didn't try it without -O3 before but i guess this is solved then :D
    channel int c0;
    __attribute__((max_work_group_size(256)))
    edit: This is not exactly my code n cbf compiling so idk which of these is faster, i had 16 channels in parallel in mine
    I have just started working with channels so my knowledge is limited. I do recall reading that you can't use "num_simd_wk_items" when implementing channels. I wonder if -O3 is trying to use that attribute. I don't know for sure, but if it was, I could see you getting that error.
    Rudy
