12 years ago
Changing cyclone II I/O current strength without re-synthesis
I would like to change several FPGA IO's current strength but without re-synthesis the project.
the project is old and already functions "on the field", hence, we prefer to reduce risks as much as possible by not re-synthesis.
all relevant I/Os are LVTTL/LVCMOS.
is it possible?
thanks
    If you still have the original project database and the Quartus Version installed that generated it, current strength can be changed in the chip editor.
    --- Quote Start ---
    --- Quote End ---
    Thanks for the answers. Which stages of the design synthesis will be changed when using the chip editor to drive different current strength?
    do i have to use the same quartus version as used in the original generation?
