12 years ago --- Quote Start --- If you still have the original project database and the Quartus Version installed that generated it, current strength can be changed in the chip editor. --- Quote End --- Thanks for the answers. Which stages of the design synthesis will be changed when using the chip editor to drive different current strength? do i have to use the same quartus version as used in the original generation?
